TwinTurbo.NET: Nissan 300ZX forum - Re: Why the 4400rpm limit?
zromtech_
on June 05, 2012 at 10:52 PM
posted by beanz
on June 05, 2012 at 02:56 PM
The knock detection code in the ECU can detect knock between 1200 and 4400rpm. The benefits to increasing the knock zone really depend on how you want your tune to behave, although the obvious advantage would be the additional safety factor.
Knock Sensor / Detonation Sensor: How it Works & How to Test
OverZealous (CT)
00:11:01 06/05/12
Re: Knock Sensor / Detonation Sensor: How it Works & How to Test
Android300zx
09:45:44 06/05/12
Thanks! Good write up...
beanz
11:58:02 06/05/12
Re: Thanks! Good write up...
zromtech
13:01:14 06/05/12
Are you going to market the software you are working on? (n/m)
Evan_Wright (Ca)
14:20:26 06/05/12
Re: Are you going to market the software you are working on?
zromtech_
22:07:49 06/05/12
beanz
14:56:02 06/05/12
It is certainly possible to detonate above 4400 rpm
OverZealous (CT)
22:11:09 06/05/12
Re: Why the 4400rpm limit? -
zromtech_
22:52:45 06/05/12
Very informative
RobZ32
12:27:40 06/05/12
Good Layout, understandable presentation. Thank You. (n/m)
Gordo 93TT Daytona
12:49:33 06/05/12
Any comment on knock sensor relocation (n/m)
ZiNnYc
19:25:21 06/05/12
It's a great temporary solution -- fuzzymonkey squeak up!
OverZealous (CT)
22:01:55 06/05/12
From the picture included -- did you end up installing
jzack
23:20:15 06/05/12
Yes, I attached just a single wire. 2-wire set up = overkill
OverZealous (CT)
14:28:18 06/06/12
Or where it is located so buried and surrounded by metal
jzack
23:24:51 06/06/12
I believe the RF shielding is pretty important. See below.
OverZealous (CT)
21:45:11 06/07/12
Nice! I would like to clarify why only one side is grounded.
DVDBURN (MD)
23:20:40 06/06/12
Another link.
DVDBURN (MD)
23:42:53 06/06/12
Woah! So do NOT connect Terminal B to anything.
OverZealous (CT)
21:37:41 06/07/12
